I'd like to change out the fluid in my manual transmission. Is it OK to use ATF even though the manual calls for like 90 wt gear oil? It says ATF can be used in cold climates but will make the tranny noisier. My tranny is already very noisy (probably lots of wear since it was low on lubricant when I bought the car due to an output shaft leak), so I'm wondering if ATF would be ok to use even though I'm not in a cold climate. I can't seem to find the 90 wt gear oil they call for - all I can find in the local autopart stores is multi viscosity hypoid gear oil.
