warning light - M Roadster
Third rock from the sun.
I've got a 2000 M Roadster (American version) with less than 2K miles on it and now for the second time the "Brake Pad Wear" warning light has come on (stays on). The first time the cause was the insulation had worn off the wire to the sensor and was touching the frame. At that time it was under warranty. I'm assuming that this is the same problem again but most likely a different wheel. Has anyone else experienced this problem?
Thanks in advance.
MM
It has to be one of two wheels as that is all that have the sensors. I have never had that problem, are your wires routed correctly and kept away from moving parts? Mine go through the dust cover on the calipers.
