weight reduction ideas
1989 325is
9
boulder
Anyone have any ideas for weight reduction other than what I have listed?
dont fill up gas tank all the way
remove: back and passenger seats, spare tire and jack, carpet and pading, stereo and speakers, a/c, ........?
402
Washington State
well if you're ripping out the ac, i'm guessing you don't mind not having windshield washer. that's an easy one to remove. if you have some money..carbine fiber intake manifolds sound sweeeeeet.
129
Kansas City, MO USA
Hmm, 10 lbs = 1 hp
Power steering pump and hoses.
Lots of insulation on firewall, floorboards, and in the doors.
The fuel tank can be replaced by a smaller fuel cell and it can be located to provide a better balance.
If you used a 3000 lb car and 300 hp as a bases.
A 10% reduction in weight yields the following:
11% more stopping power per lb
11% more contact patch per lb
11% more hp per lb
In addition the ride will be comparably stiffer because you have the same spring rate with fewer lbs riding on it
You will get better gas mileage .
Later,
402
Washington State
montokboy said:
you really don't need the steering wheel either
drive with the force
[rofl] [rofl] no, but seriously..ron knows his sh*t apparently. however, if you're looking into weight reduction, i'm guessing you wanna race...maybe autocross? in which case, you WILL want your power steering. and you may consider keeping the steering wheel. just as memorabilia, if nothing else.
368
Ventura CA
Remove the dash cover, get carbon fiber trunk lid and hood, remove the headliner and all the interior panels. If you're really serious pull the glass out of the doors, although at higher speeds the drag of an open window can be more than the weight savings.
Steve
