weird temp gauge problem
98540iguy
houston, texas
I have a 1998 540i and the engine temp gauge is acting up. When you turn the car on it will go to the correct engine temp, pause for a second, then shoot to max hot. After you drive for a while it will come back down to the normal range where it should be. I know the car is not overheating and the coolant is full, I also replaced the temp sensor, what else could it be?
Jack
98540iguy
houston, texas
Thanks for the advice, is there any way to double check this? Are the individual gauges available for this car or do I have to buy a whole cluter? Is there anywhere I can send the cluster to have it repaired?
I have also found some info about the capacitors going bad in these, do you think that could be causing my problem?
Jack
