wheel bearings
34
North Carolina
has anyone replaced their rear wheel bearings before?
i'm going off of the bentley manual here, and it doesn't seem too nasty except for repeated phrases such as: 'some special tools may be required. if you don't have adequate time or space, it may be better to have a BMW dealership perform this maintenance'
so....do i have to buy a puller from advance auto parts for 2 bucks? or do i need some special 70 dollar gizmo from Germany?
in terms of difficulty, is this procedure on par with a water pump replacement, or a clutch job?
i'm tired of these strange grinding noises!
793
Bay Of Islands, NZ
Getting the bearing out is a bloody mission without a decent puller, and even then. Also, don't even try removing the large locking nut without a rattle gun. Plus you need a very very decent torque wrench to do it up.
So, yes it is a bloody pain in the arse job, but doable. So much easier with the trailing arm out of the vehicle, esp if you plan on doing it without a puller. Need hammer swinging room. (I don't recommend doing it this way, but you can).
Not trying to put you off, but the warnings in the bentley are there for a reason.
1,271
Toronto, Canada
I've never done one, never had to... but I've read up on how to do them, and they're on the list with "rear subframe bushings" and "rebuilding engine" on the "Things I won't do" list. Good luck, let us know how it goes if you do it yourself.
29
Orem, Ut
Iv done engine swaps, clutch jobs and struts/shocks and springs and i took my car to my Big O to have them do it. It's a PAIN! For a good shop it's a 2 hour job per side.
