Ah I see,
Im only after quite thin spacers for the front wheels (2-3mm thick) as the offset on my wheels sit stupidly close to the callipers.
I've put up with it untill now, and its starting to annoy me knowing that they are so close, just need something thing to give it abit more.
do you thing making sapces 2-3mm think would mean id need longer wheel studs? could i just use the stock studs if i made spacers this thick.
im pritty good at the lathe as i use it all the time for work, but i could also get one of the tradesman to give me a hand so thats not a worry actually making the spacer.
Thoughts?, and cheers.
