bichmgnt (love that name btw
![Wink [;)] [;)]](/images/smilies/wink.png)
...lol)
Anywho...hopefully I can answer your question without too much confusion
To start off...whee need to know the difference between positive and negative offset. To understand this...please switch to thinking mode
. If you are facing the wheel from the front (looking at the tread not the rim face) draw an imaginary line down the center of the wheel.
Now...if the portion that mounts to the hub/the car is towards the outside/away from the car, this is called
positive offset. If the mounting area is at the center of the wheel there is
no offset. Anything that is closer to the car is considered
negative offset.
Now...this means that if your wheels are the stock 6x14 wheels and have the
35mm positive offset...you're wheels will be in the normal place and will work just fine.
If the wheels are the same...6x14 and have a
25mm positive offset, since the mounting area is closer to the car...the wheel will mount further away from the car...to a point, the may even stick out of the side of the fender well.
If the same 6x14 wheel has a
45mm positive offset, then the mounting surface is further away from the car...and the wheel will move farther into the wheel well to compensate. At this point is where you run into rubbing problems. Normally, the best way to solve a problem like this is to purchase a set of HUBCENTRIC spacers. I say hubcentric because they hold the wheel in place more effectively than a flat spacer. H&R makes the best ones that I'm aware off. To make this wheel fit properly, you would need a 10mm spacer to compensate for the addition 10mm of positive offset.
So if you take nothing else away from this post...Positive offset brings the wheel closer to the car...Negative offset pushes it away from the car. For the e30 (not IX or M3) anything that is 35mm Positive Offset or less (i.e. +25mm, +10mm, etc) will fit fine...as long as there is room for the tire to clear. If you upgrade to a larger wheel...compensate by decreasing the series of your tire. Stock series is 195/60R14 or 195/65R14. If you go to a 6x17 (example only) rim...try 195/45R17 or 195/40R17.
Please let me know if I need to clarify more
![Thumbs Up [thumb] [thumb]](/images/smilies/icon_smile_thumb.gif)
