Wont start???
Florida
Hello all,
Well I have a 1990 325i 4dr well it wont start the guy I got it from said he was driving down the road and it just lost power and it has not started since.
Well I have pulled the plugs and replaced them when they were out I laid them on the head and hooked them up turned the motor over and they all fired off a bright blue spark. So I thought fuel well I tried squirting fuel straight into the intkae no luck wont start so I pulled the fuel rail and injectors out of the motor hooked them back up while resting them on th intake and turned the motor over they all spray. So I opened the oil fill and turned the motor over and the rocker arms are moving so its not a timming belt. It seems like it is maybe firing 1 or 2 cylinders but thats it any ideas? Please help I am now lost.
Ben
576
NY
the timing belt could have slipped a couple teeth, so check that. also check the air flow meter, as the car will not start if its not hooked up or not working
