z3 tech advice please
ksealy
SC
hi im new here and hop i can come back often. in the meantime, i am having a problem with a 1998 BMW Z3. straight 6
The fuel pressure is good, but the injectors are not working and will cost $175 each x 6.
I have a feeling this might be something inboard as maybe a comman censor.
Does any one else have a clue or any advice?
Anything will be much appreciated, i will check back often and then let you know how it all came out. please i neeed help.
Thankyou so much for your time
Kelly SEaly
Does it run at all? How do you know all 6 injectors are not working? If all 6 are not working, you either had a major fuel contamination, or there is a more central problem with the ECU or wiring. It's hard to image that all 6 injectors failed at the same time.
I have to agree with Kirby on this one. I have never seen six injectors go at once. Bad gas could have fouled them in that case get them cleaned not replaced. Or like Kirby said we have another issue? Who made the diagnosis?
