First post on the new forum, hopefully it works.
Well the E30-323ti project is almost ready for road testing.
Just waiting on the radiator to be completed then I can do the Intercooler plumbing, and go for a drive.
Anyways, the brakes.
I have upgraded to 290x26mm discs and 2 pot calipers.
The discs are from a late model Nissan Patrol (305x26mm), I had to machine mine down to 290mm dia because of the old skool 16" wheels I'm using. The central hole needed to be machined to 120.3mm to fit over the E30 Hub.
I have used 8mm thick bissalloy 80 plate as the rotor hats (surface ground) which are bolted to the rotor by 6xM12 CS Allen bolts. The hat fits the hub as per the OE discs.
The 2pot calipers are from a Lancer EVO 4 (same as 2g DSM eclipse calipers).
Caliper brackets are also required.
The discs also come in a 295x20mm size which can be used with the stock E30 calipers (caliper bracket needed).
I have a few pic's of the setup if someone can host them for me.
Hope you all find this useful.
Later
Glenn![Big Grin [:D] [:D]](/images/smilies/biggrin.png)
Later
Glenn
