Mr.W said:
What model BMW do you have? How many miles/km?
We must know these things to be able to help you
sorry, I have a 1984, 318i, it's got 190k plus on it
the a/c works great (except when idling when it's hot out, which I've heard can be fixed by replacing the fan clutch), i've replaced fuel pump, fuel filter, fuel pressure regulator, AFM, ACV, ACU, recently cleaned out fuel injectors replacing wires and spark plugs, distr cap
like i said, it only happens when i have the a/c turned on. i know i probably need to replace the fan clutch, since at idle in hot temp, the temp guage is above normal and the cold air doesn't flow sometimes until i hit the accelerator, just wondering if the fan clutch has anything to do with the jerky and lagging acceleration. or something else. thanks
