after i soldered the wire in the wire harness to the ICU, i discovered the O2 sensor wire was unplugged. when i connected it, i got choppy acceleration again. i removed the old O2 sensor and it was all clogged up, so i replaced it. acceleration was good for a day, then i got choppy acceleration again for some reason, so i've been messing round with the throttle position switch. now i have sporadic choppy acceleration. so the next thing will be to get a new throttle position switch. i'm not entirely convinced mine is bad though. i've followed bentley's testing of the throttle position switch (TPS), but i'm getting mixed results. slight actuation of the throttle produces continuity. i think it's failing the half way test though. is the TPS supposed to show a reading on the ohmometer when at rest? bentley sort of gives mixed. it states that you should adjust TPS so there is continuity (0 ohms), but in the testing portion of the paragraph it says the TPS should register continuity when throttle is slightly activated (.002-.006 from rest position). this suggests that at rest position the TPS should not have continuity, so there should be some reading on the ohmometer, which i get. anyone have any suggestions? i guess i'll end up replacing the TPS in the end. I've replaced lots of parts thus far that have not proven faulty or fixed the problems i've been having (high operating temp, choppy acceleration). since they are relatively minor in cost, i figure that replacing the parts are preventative since it does not look like they've been replaced in a long time if ever (thermostat, hi/lo aux fan switches, coolant temp switch, radiator hoses, flushing radiator, fuel pumps, fuel pressure regulator, spark plugs, O2 sensor, ICV, ICU). at least i changed the philips head screws on the TPS with allen headed screws to make it easier to remove and add a new one when I decide to.
i guess that is one suggestion that I haven't seen on these boards before is to replace easily stripped screws with bolt head or allen headed screws to make easier to replace parts, especially on routine maintenance items.
anyways, if anyone has any thoughts on my now intermittent choppy acceleration problem, I would be greatful. I do have one more question. There is no wire to pin 8 going to the ICU, but there is a wire going to pin 7 of the ICU. According to Bentley, pin 7 is for auto trans. position and you test it in park or neutral. I'm not sure what this does since i have a manual transmission. anyone have a clue of this or what pin 8 is supposed to do? I have '84 318i. thanks
