That's what happens when you use your bumpstops as springs.
Anyway, the turbo is technically an exhaust driven supercharger. There are also two kinds of superchargers:
The centrifugal, which is basically the exhaust half of a turbo driven by a belt, and the Roots type blower, which is two interlocking screws. The difference is that a centrifugal SC builds boost exponentially depending on RPM. You won't notice much on the low end except for a mean whistle, but power climbs very rapidly as revs rise. Centrifugal SCs are generally used where space is an issue as they're small and don't require much aside from a belt and some tubing.
Roots type blowers are OE equipment on many cars such as the Kompressor Benzses, F150 Lightnings, and basically anything supercharged from the factory have good reliability provied you don't have a really small pulley on it. They're the kind that sit on top of an engine like those old muscle cars have. If you ever look at the dyno chart of a Roots blower, it's basically the stock curves but higher on the chart. The Roots has the best response (although less effeciency and less peak power) time and can build full boost the instant you put your foot down.
All with the exception of turbochargers have parasitic drag to some degree, Roots being the worst in this case. Mercedes counters by using an electromagnetic pulley that engages at part throttle. It gets rid of any parasitic drag the supercharger might have at part throttle. If any of you want to hear what a supercharger sounds like when it's permanently attached to the engine, follow this link:
http://www.corradocentral.com/movies/driveby.mpg
If I'm missing anything, or you guys want anything clarified, just reply.
