BMW CHECK LIST ITEM
INTERIOR
Buttons
Windows
Fan Blower
A/C
Sunroof--look for rust where the tracks are
Seat--remove seat covers – re-upholstering jobs run $500 - $2,000 for the front seats alone
Dashboard, console for cracks or signs of wear
Carpet – decent shape
Pull to inspect floor pans for rust (rear cabin)
Lights on instrument cluster light up when the key is turned to position 1 or 2, and go dark once the car is started. It is very common for people to disconnect or remove the light bulbs to hide problems
Radio
Power mirrors
Power locks
Power sunroof
Flashers
Turn signals
Brake lights
Fog lights
Headlights
UNDER THE HOOD
Steering rack ($500)
Control arms ($500)
Driveshaft ($800)
Radiator ($250)
Brakes ($500)
SI Board ($250)
Timing belt ($400)(not applicable on M42 engine)---- Record of last change
Battery $ 100
Clutch $ 800
Various electronics $ 0-1,000
Auto Transmission $ 1,000
ENGINE COMPARTMENT
Engine clean
Leaks – head gasket
Oil Level / Oil conditionWhat color is the oil? ... any metal flakes in it?
Straight Frame
VIN # consistency… The VINS should be found on both front fenders. The rear fenders do not have VIN stickers.
Signs of repair
Chain tensioner
Profile gasket
Shock towers - excessive weld lines could be repair - accident or collapsed shock tower.
Dipstick for signs of coolant (cracked block)
Check condition / color of fluid containers
Water pump (check for leaks)
Same with the power steering pump
chirping noise from blower fan = last legs
belts are in good shape (timing belt especially),
TRUNK
Water accumulation
Spare Tire
Tool Kit
Signs of repair ( pull back carpet)
EXTERIOR
Check body panels for damage/signs of repair.
Do VIN numbers match.
Look for anything out of the ordinary.
Aftermarket stuff can hide dents or damage.
Check the head and taillights for cracks or pits.
Make sure that entire door locks work properly.
TIRES
Tread life on tires
Uneven tire wear
Rims for damage
UNDER SIDE
Rust on the floor pans
Rust on the drive train
Rust on the exhaust
Check the steering rack boots for leaks
TEST DRIVE
How does the car idle? ...Check for a rough idle, hesitation, and knocks.
The engine should be pretty smooth unless it is modified by performance upgrades like camshafts.
Make sure the car can pull to redline without drama.
Make sure the shifting is smooth and swift (short shifters can feel notchy).
Check for a hard brake pedal and smooth stops.
The handling and ride should be up to usual BMW standards (stiff but sweet).
Make sure the E-brake is tight and holds the car in place.
Does the car stay straight when you slam on the brakes and let go of the steering wheel?
Does the steering wheel turn when you go over potholes?
Any grinding or knocking (not ticking) in the engine bay?
How about when you rev high then release?
When you slam on the gas then release, any knocking sounds from the shock mounts?..
Sub frame?
Differential whine. If you hear any loud noises from the rear, STAY AWAY.
buzzing or humming from the wheels (wheel bearing)...
If manual how's the clutch? how easily does the car shift from 1st to 2nd without depressing the clutch?.. If you push gently it should be able to slide right in without any grinding.
Any play in the steering wheel? ...
ABS kick in when you slam on the brakes?
Good Luck [bmwdance]
INTERIOR
Buttons
Windows
Fan Blower
A/C
Radio
Power mirrors
Power locks
Power sunroof
Flashers
Turn signals
Brake lights
Fog lights
Headlights
UNDER THE HOOD
Control arms ($500)
Driveshaft ($800)
Radiator ($250)
Brakes ($500)
SI Board ($250)
Battery $ 100
Clutch $ 800
ENGINE COMPARTMENT
Engine clean
Leaks – head gasket
Straight Frame
Signs of repair
Chain tensioner
Profile gasket
TRUNK
Water accumulation
Spare Tire
Tool Kit
EXTERIOR
TIRES
Tread life on tires
Uneven tire wear
Rims for damage
UNDER SIDE
Rust on the exhaust
TEST DRIVE
Sub frame?
